pivot bushings
Jason
pivot bushings
Post by Jason »
I am installing a new set of axle pivot bushings for the first time, and I am not sure if they will need to be pressed in or if i can install them myself? Is this a difficult process or can i do it in a day in my driveway. and last but most importantly is there any tricks or tips i should know about?
Thanks for any help you can give me
1967 F100 SWB step-side, 300" 6cyl, T-18 transmission and Dana 60-3 rear end with 3.54s
iamthewreckingcrew
re: pivot bushings
Post by iamthewreckingcrew »
Do you mean the bushings where the I-beam attaches to the frame? If so, then no you don't have to press them in. I tore my old ones up pretty bad getting them out, but the new ones went in pretty easy. I didn't have to press anything in when I swapped I-beams and I replaced all the bushings.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
Jason
re: pivot bushings
Post by Jason »
yes the bushings i am talking about is the ones on the I-beams. I am not so much worried about the ones on the radius arms they appear to be simple enough. thanks for the info! I just want to make sure I have as much info as possible sense this is my daily driver.
iamthewreckingcrew
re: pivot bushings
No problem. I'm sure you could change out all the bushings in a good day.
I took my front end apart recently to swap the springs side to side and it took about an hour total. I had the springs on the wrong sides. :oops:
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
Maltybuck
re: pivot bushings
Post by Maltybuck »
Just to piggyback onto this thread, I also need to swap an axle pivot bushing on a 69 2-wheel drive soon. Once I loosen and remove the main bolt that attaches the axle to the frame, will I be able to pull the I-beam axle down far enough to install the new bushing? Will the wheel that is connected to the other end of that I-beam need to be jacked up off the ground? It seems like pulling down on the I-beam will cause the wheel to want to tilt and the radius arm will want to twist. Not sure if there's enough play to pull down the I-beam far enough, or if I need to loosen up other parts of the suspension.
Thanks!
BobbyFord
Re: re: pivot bushings
Post by BobbyFord »
Maltybuck wrote:Just to piggyback onto this thread, I also need to swap an axle pivot bushing on a 69 2-wheel drive soon. Once I loosen and remove the main bolt that attaches the axle to the frame, will I be able to pull the I-beam axle down far enough to install the new bushing? Will the wheel that is connected to the other end of that I-beam need to be jacked up off the ground? It seems like pulling down on the I-beam will cause the wheel to want to tilt and the radius arm will want to twist. Not sure if there's enough play to pull down the I-beam far enough, or if I need to loosen up other parts of the suspension.
Thanks!
I did my dads not too long ago. I jacked the truck up just a little and put jack stands under the frame, on each side, up near the front, left the tires on, slid my floor jack under one beam near the pivot bushing and pulled out the pivot bolt and pryed the axle pivot out of the frame. I then used a chisle bit on my air hammer and popped out the old bushing. Then I used a couple of washers, a cup-shaped piece of metal and a long nut and bolt and used my 1/2 drive impact to tighten the nut-bolt-washer-cup set up and press the bushing in. Both sides took less than an hour total.
Joshpow
re: pivot bushings
Post by Joshpow »
This is some good info for me guys. One question I have is are 67-72 pivot bushings the same as a 77. I have a total bushing kit picked out for a 72, but I don't know if the pivot bushings and radius bushings will work on the 77 beams I pan to use.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
Jason
re: pivot bushings
Post by Jason »
I am pretty sure the bushings are the same. I have read this site many times and nothing says differently that I have found though I have been known to be wrong once. LOL
iamthewreckingcrew
re: pivot bushings
I used 77 I Beams on my 68 and didn't buy any year specific bushings.
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
Maltybuck
Post by Maltybuck »
BobbyFord wrote: I did my dads not too long ago. I jacked the truck up just a little and put jack stands under the frame, on each side, up near the front, left the tires on, slid my floor jack under one beam near the pivot bushing and pulled out the pivot bolt and pryed the axle pivot out of the frame. I then used a chisle bit on my air hammer and popped out the old bushing. Then I used a couple of washers, a cup-shaped piece of metal and a long nut and bolt and used my 1/2 drive impact to tighten the nut-bolt-washer-cup set up and press the bushing in. Both sides took less than an hour total.
Thanks for the info. I ordered both bushings, the standard and the urethane/performance type that re-uses the old metal sleeve. Hopefully I won't have to pry out the old sleeve. If the parts arrive by this weekend, I'll give is a shot and report back.
Thank for your help.
Joshpow
re: pivot bushings
Post by Joshpow »
Thanks guys. Glad to hear that the bushings are the same.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
Jason
re: pivot bushings
Post by Jason »
ok i was under the truck last night and was looking at the bushings to see how bad it really was. The Radius arm bushings are shot but the pivot arm bushings look and feel fine ( couldn't find any movement ) how do tell if they really need replaced. I don't want to tear it apart until i figure out if I want to replace the entire front end. But i will do the Radius arm bushing since they are nearly gone
cdherman
Post by cdherman »
My 40 year old axel bushings were not in bad shape either. I replaced them, but I have read elsewhere that the axel bushings are usually OK. If you can take back your new bushings or you havn't purchased them yet, I'd say its safe to just keep the old ones.....
flyboy2610
re: pivot bushings
Post by flyboy2610 »
Most all urethane bushing kits do not come with the outer shell. You must reuse the ones on your truck.
You do not have to remove the outer shells. When I removed the rubber portion of mine, I drilled a good number of holes through the rubber, then pried it out with a long screwdriver and chisel. The urethane bushings then slid into the outer shells with no problem.
This job is easier if you remove the I-beams from the vehicle.
69timemachine
re: pivot bushings
Post by 69timemachine »
:yt:
In case you decide to go ahead and change them, you may have little scraps of rubber left in the bushing shells after you extract the old rubber. You can use a small wire wheel on a die grinder or drill to clean the bushing shells. Don't forget to use silicone grease to lube the new poly bushings and keep them from squeaking. :thup:
Jason
'06 Mustang GT 5-speed
