lost my park
- westernkansas
lost my park
ok this started on friday, usually when i start my truck i have to pull up on the shifter to start but now my automatic 72 with a 390 not sure of the tranny think it is the c6. i have to run through the tree to find a spot the truck will start in and just now as i got to work park is now reverse, how do i adjust the linkage to get everything in the right place or is it something totally different.....will check back after 4pm to answer any questions, plan on trying to fix it during lunch break at 6. thanks fopr any help
- GSequoia
First, yes, you have a C6.
Second your Neutral Start Switch is going out, I'd bet your reverse lights don't work either (they both use the same switch).
I'm not sure if Ford NSS's are rebuildable, I'd suggest searching here for "Neutral Start Switch," "NSS," and "back up switch."
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
- westernkansas
- convincor
re: lost my park
lost your park, park is now reverse
adjustments usally don't move like that... How's your cab mounts??
"Still Plays With Trucks"
