330 engine
330 engine
could use some help on a 1970 ford 330 industrial in a f-600. i'm wondering if the engine parts can be interchanged with other ford smallblocks, such as carb, fuel pump distributor, etc. i know it's not a pickup but i'm hoping some of you ford guys can help
if it was easy it wouldn't be worth doing
- sideoilerfe
re: 330 engine
They are completely different engines. Maybe the carburetor but that's about it.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
this truck runs beautiful at an idle an when she wants to she's a powerhouse having some trouble hesitating and stalling going up hills i've loaded it a little over26,000 truck weighs 8900 pulled beautiful next day it doesn't want to run enough to pull a 25% grade
- AlleyCat
re: 330 engine
A 330 is an FT series engine which is a truckized version of an FE engine. It bigger brothers are 361 and 391. There were a couple different versions of the 330.
Any good parts store should have listings for parts. If you have a good independent or a NAPA near you I'd try them first.
I would check fuel filter and lines first. Then I'd take a look at points and plugs. The fuel pump is a possibility but unless it's leaking I'd change the filter first.
The coil is unlikely because in most cases when a coil fails it's done.![Smile :)](./images/smilies/icon_smile.gif)
Clay
re: 330 engine
thanks for the help gonna try a few things i'll keep ya posted
