Cooling ?
Cooling ?
My 67 has a 300 inline six. I had not run it in a while, because I went from 3 on the tree to a automatic C4. Got it back on the road yesterday. It was running hot at about 220 when I remember it used to run at about 180 or 190. I took out the thermostat and replaced with a new one that read 180 on it. Took it for a spin today and same problem it was reading about 200. Any idea what is going on?
Camel Ciggarettes,John Deere and Ford "Hard To Beat"!!!!
- marine6212
re: Cooling ?
I might be talking like a idiot but did you hook up the cooling lines on the C-4? the radiator might be too small for the cooling of the engine and tranny!!just my
I'm no expert on these truck's trying to learn about them as I go!!
![2 cents :2cents:](./images/smilies/icon_2cents.gif)
We all came together, both young and old.
To fight for our freedom, to stand and be bold.
In the midst of all evil, we stand our ground.
And we protect our country from all terror around. Peace and not war, is what some people say. But I'll give my life, so you can live the American way. I give you the right to talk of your peace. To stand in your groups, and protest in our streets. But still I fight on, I don't bitch, I don't whine.
re: Cooling ?
Hey I learn as I go also. No worries. Actually I added a seperate cooler for the tranny. I think I am going to remove the thermostat all togther. Should run cooler then. ![Pray :pray:](./images/smilies/icon_pray.gif)
- basketcase0302
re: Cooling ?
I was taught this is one of the worse things anyone can do in an attempt to cool an engine.I think I am going to remove the thermostat all togther. Should run cooler then.
The coolant has to have a chance for the radiator to cool it down.
The thermostat restricts or slow it's flow to give the radiator a chance to do it's work.
Put a restrictor plate in but don't just pull the entire t-stat out.
I'd look real hard at the cooling fins for restriction or blockage of airflow first.
And then do a leak-down pressure test on the entire coolant system.
(Most Discount, O'Reileys, Advance or Pep Boys will do this for ya' for free.
Basketcase
re: Cooling ?
Thanks,
One thing I forgot to mention is the fan shroud is missing in my 67. I didnt mention it only cuz I never had one before and the cooling was never a problem. Anyways I took it for another spin today. I notice that when I am driving down the road it holds steady cool temp., but when I get home and leave it running is when it begins to heat up. Could the missing fan shroud make all the difference?
- F100builder
re: Cooling ?
Believe it or not, a bad radiator cap can cause overheating if the spring is worn out. If you have no leaks and low coolant is not the issue, then I would try flushing the system and adding new coolant (50/50 mix) and a new cap. Leave the new 180 deg. thermostat in place!
Patrick
![Image](http://i264.photobucket.com/albums/ii183/F100builder/1969%20F100/P3220011-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/CAXW6TDZ-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan0019-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan-1.jpg)
- fordman72
re: Cooling ?
The shroud would help, not sure how long it sat but maybe flush the radiator and get good mix of antifreeze and water.
72 Ford sport custom swb 351w C4
69 F-100 240ci 4 speed
96 F-250 4x4 built 351w, heads,cam intake, etc
97 Mustang(wifes show car)
90 Mustang GT 351w bored and stroked to 410ci
93 Ford Ranger 4cyl 5speed swb(gas milage)
07 Ford Escape Blazing Copper color(wifesdaily)
- j41385
re: Cooling ?
The inline 6 trucks never had a Fan shroud. The Fan is close enough to the radiator not to need it.
![Image](http://castboolits.gunloads.com//images/smilies/Broken-Image-Fighters.gif)
![Image](http://img504.imageshack.us/img504/2430/evanuy6.gif)
![Image](http://fordsix.com/forum/images/avatars/gallery/personal/spincam.gif)
- jzjames
re: Cooling ?
maybe your temp sender or guage is not just right. ![Razz :P](./images/smilies/icon_razz.gif)
