Alternator Bracket 302
WickedSix
Post by WickedSix »
I pulled my 240 out and put in a 302 in my '67. I bought a chrome alternator bracket for a 289/302, but I cannot figure out how it mounts. I was going to see if anyone had a picture where I could see how everything goes.
Thanks!
Hawkrod
re: Alternator Bracket 302
Post by Hawkrod »
You may have a problem. There are two totally different sets of brackets and pulleys for a 302. There are 69 and older and 70 and newer. What year was the bracket for and what year is the engine you have? If the fit isn't obvious you likely have teh wrong combo. The easiest way to tell what engine you have is to look at the harmonic balancer. If it has 4 bolts holding the pulley on it is 70 and newer and 3 bolts is 69 and older although there are some 70-72 vans and trucks that violate this rule and have the 3 bolt stuff. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
WickedSix
Post by WickedSix »
It's a '79 engine, it has the 4 bolts. The alternator bracket I have looks like this one http://store.summitracing.com/partdetai ... toview=sku
I just can't seem to get it mounted right.
Hawkrod
Re: re: Alternator Bracket 302
Post by Hawkrod »
WickedSix wrote:It's a '79 engine, it has the 4 bolts. The alternator bracket I have looks like this one http://store.summitracing.com/partdetai ... toview=sku
Yeah, you will never get those mounted. They changed the water pump in 70 and those brackets fit the 65-69 not the 70 and newer. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
WickedSix
Post by WickedSix »
I had a feeling that was the case, thanks for the help, guess I'll start looking on ebay!
basketcase0302
Post by basketcase0302 »
WickedSix,
They got quite a few of them on there right now:
http://shop.ebay.com/?_from=R40&_trksid ... Categories
Basketcase
