should i get tranny overhaul or get a remanufactured
LUVMY69FORD250RANGER
Post by LUVMY69FORD250RANGER »
ac delco sells the highly tested c6 on ebay for 400,. also a mechanic told me that overhauling a c-6 thats in the truck is a waste due to it getting so hot in the tranny. thanks for advice.
THANKS
spartman
Post by spartman »
I thought you had an FMX tranny?
What engine is it going to bolt on to?
Your mechanic is a moron BTW.
convincor
re: should i get tranny overhaul or get a remanufactured
Post by convincor »
Fortunatly, these guy's a local to me. :thup:
http://www.dynamicracingtrans.com/index.htm
"Still Plays With Trucks"
Redcap
Post by Redcap »
Rebuild your existing transmission.
TRANNY
spartman wrote:I thought you had an FMX tranny?
ITS GONNA go on a 390 v8 ...
THANKS
spartman
Post by spartman »
Then for a 390 an FMX or a c-6 is the recommended options.
FMX will have a little less drag and loss than a C-6.
As far as rebuilding either of these transmissions, it is fairly simple as long as you take your time and document how it all came apart.
The most expensive part will be the converter.
spartman wrote:Then for a 390 an FMX or a c-6 is the recommended options.
yeah, the ac delco one on ebay. is 450. with a fee tourque converter, they
got 120 pos no negs., seems like the quickest option. im unsure bout having a guy fom craigslist rebuild a tranny, shops want 1200. the ebay one said to be better than original tranny.
THANKS
spartman
Post by spartman »
1200 seems steep for a rebuild.
Round here I can have one done for about 450.
Thats from a reputable shop.
BobbyFord
Post by BobbyFord »
You could probably rebuild yours for $200-$250 + fluid.
