I am building a 390 from a 360 for my new project, a 72 F100 XLT SWB 4x4 4 speed.
I am planning on replacing the distributor and going electronic.
I have a parts donor 79 F250 2WD, 460 cu with Duraspark.
I'd like to use the dist. form the 79 in my 72.
Does anyone know if the Dist. form the 460 will fit in my 360/390 rebuild?
Also, as an alternative to the swapped Duraspark, does anyone have recommendations for another aftermarket electronic ignition system, MSD, DUI, Mallory, etc.
Your thoughts and suggestions are appreciated.
Yours, Sean Malis
Will a Duraspark from 460 fit in a 360?
- F10YRB12118
Sean
1942 Chevy Truck, 1.5 Ton, G503
1967 F100 352 LWB Custom Cab
1969 Bronco Wagon 302
1972 F100 360 SWB 4x4 XLT
1972 F250 360 LWB Parts Donor
1973 F250 360 LWB 4x4 Donor?
1979 F250 460 Parts Donor
- j41385
re: Will a Duraspark from 460 fit in a 360?
Nope the FE and 385 Series have different distributors.
![Image](http://castboolits.gunloads.com//images/smilies/Broken-Image-Fighters.gif)
![Image](http://img504.imageshack.us/img504/2430/evanuy6.gif)
![Image](http://fordsix.com/forum/images/avatars/gallery/personal/spincam.gif)
I think you can transfer the guts to yours. I know this has been done on here before.
sorry off topic and a small hijack. On your 79 do you have the plastic in frame gas tank?? I need some parts off it, if you have it and are willing to sell those parts?? I need the part that hooks the filler tube and vent tube to the tank itself.
http://i95.photobucket.com/albums/l158/ ... IM2573.jpg
- F100builder
I just installed the Pertronix Ignitor in my '69 with a 390 and it took about 30-45 minutes (added an MSD Blaster coil too) and my idle cleaned up and the stumbling from a stop sign/light has gone away. I can even spin the tires a little longer!
It's so easy it practically installs itself and I strongly recommend it. Plus, if you're in to keeping a stock appearance, it all tucks under the distributor cap and looks completely stock. Never change points again! It's also less $$$ than a new distributor.
![Evil :evil:](./images/smilies/icon_evil.gif)
Patrick
![Image](http://i264.photobucket.com/albums/ii183/F100builder/1969%20F100/P3220011-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/CAXW6TDZ-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan0019-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan-1.jpg)
- Dragon
I use the Accel points eliminator and goofing off it took 20 minutes.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away.![Smile :)](./images/smilies/icon_smile.gif)
My Gallery
Spark test
My Gallery
Spark test
- Dragon
I put a Super Stock Accel coil on but I didn't have to.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
