Tranny help bout draining
i got a 69 ranger, i think its a c-6 , cant seem to find a drain plug. is there one that you drain by taking off the pan??? thanks. never taken off a pan before, what should i expect.
THANKS
- sideoilerfe
re: Tranny help bout draining
There is no drain plug. Expect transmission fluid to come out when you remove the pan.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- basketcase0302
You also want to pull the inspection cover, spin the engine over so the torque converter drain plug is on the bottom, and drain it too.
Make sure you pour a few quarts of fluid back into it before you try to start it or you'll burn the pump up in the tranny.
