converter question
- green70
converter question
i have a c6 w/converter from the 71 f350 camper that i parted,question is,will i have any troubles using the converter in a half ton p/u?,or will i need to use one from a f100?
- fourtss
re: converter question
almost all tranny's have serval applications,for T/C if you are swapping tranny's from the F-350 then it will work, if you still have the old t/c from the F-100 you need to see if the #'s match
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
2003 ford escape
- green70
the truck has no trans in it right now
