proper way to check trans fluid?
- ChrisW004
Got a newbie question. What's the right way check trans fluid? Check hot or cold? Engine running or not?
And anyone know the capacity of a C4? Thanks!!!
Chris W
- TheEskimo
- flatblack
re: proper way to check trans fluid?
what i do to warm up the transmission so you get a proper reading is drive it around the block then once your parked shift it down all the gears then back up to park and check it.
- ChrisW004
- basketcase0302
Chris,
"Uncle Chilton's" sez' your 70' should take 10.5 quarts, (it's wrong though)....
I just did the 71' Chero and after draining the torque converter it took me around 12 quarts.
Tranny cooler and size will make this differ.
Give it at least a few quarts though before you restart it.
- Wes
Warm running in park P-brake set wheels choked on level ground.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- F100builder
Whoa. Wes, sounds like you've had a run away before. Chocking the wheels too?
Patrick
I start the truck, shift it through all the gears, and let it idle for a little bit.
Then with the truck running I check the fluid while the truck is in park.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- F100builder
That's what I do. Or I check right when I get back from driving somewhere while it's still hot.mrsnicks wrote:I start the truck, shift it through all the gears, and let it idle for a little bit.
Patrick
Patrick
- 1971ford
Re: re: proper way to check trans fluid?
F100builder wrote:Whoa. Wes, sounds like you've had a run away before. Chocking the wheels too?
-Ryan
- Wes
Um there was a nation wide recall on ford auto trans slipping in revere from park, while the driver was out opening gate garage doors and what not. My shop foreman was pin against a bench 1 time when an e350 ambulance drop into reverse. He wasn't hurt, got a good bruise thou.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
Re: proper way to check trans fluid?
ChrisW004 wrote:Got a newbie question. What's the right way check trans fluid? Check hot or cold? Engine running or not?
, chris COOL truck got any pics, rims are perfect choice
THANKS
Of course, the other debate is what to use in a C4. After a lot of research all over, I concluded that Type F is still the right choice, even in a rebuilt C4. I ended up using Amsoil SuperShift which is their Type F product. Frankly, it shifts a little TOO firm for my taste.
Took me 11.5 quarts to fill 'er up as well, but that was with a deep pan.
Check hot, after cycling through all the gears, then leave it in P. Parking brake for good measure and I guess wheel chocks if you are paranoid and/or have a crappy P-brake.......
