70 F100 Tranny
FordTruck
70 F100 Tranny
Post by FordTruck »
I Was Wanting To Know If The Tranny From A 300 Would Fit My 302 Because The FMX Thats In The Truck Just Isn't Working.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
AlleyCat
re: 70 F100 Tranny
Post by AlleyCat »
Bell housing pattern is the same. :)
Clay
FordTruck
re: 70 F100 Tranny
Post by FordTruck »
What Changes Will I Have To Make With The Drive Shaft? The One In The Truck Has A Carrier Bearing And The Tranny Is Coming Out Of A Van It Dosen't.
That's Awosome If The Tranny Off The 300 6cyl Will Fit Its A C4 But That's Better Than A FMX That Don't Work Most Of The Time.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
AlleyCat
re: 70 F100 Tranny
Post by AlleyCat »
You'll have to measure the length of both trannys.The truck driveshaft should bolt to the rear of the trans while the van shaft will slip into the trans.Most likely you'll have to get the front section of your driveshaft shortened and the slip yoke installed. :)
Clay
FordTruck
re: 70 F100 Tranny
Post by FordTruck »
The One That's In My truck Now Has A Slip Yoke It Just Slides In Also But Next Time I Work On My Truck I'll Just Take Some Measurements. Sorry For All The Questions But What About The Crossmember What's Different With Those?
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
AlleyCat
re: 70 F100 Tranny
Post by AlleyCat »
You just might get lucky and the shaft will work out without mods.You can reuse your original crossmember.The trans crossmembers on bumps are all the same.You may have to swap the trans mount from your FMX to the C4.The bolt spacing on the mounts is the same for both trannys.
No need to apologize for the questions. :) In fact keep 'em coming.That's what we're all here for. :D
Clay
