CruiseOMatic for C6 swap
brainfart3
Post by brainfart3 »
67 F250 w/352 - COM finally bit the dust. Unable to find anyone around here willing to recuild it.
so - i ve located a C6 from a 72 F250 that was behind 390.
Today we pulled he old out and bolted up the C6.
with the 2 trans sitting side by side i noticed a few differences
1) the C6 is about 2" longer than the COM - i beleife the slip-joint will allow that to work.
2) transmission moun on the C6 is about 2" behind the COM - not an issue - there are slots in the crossmember and additional holes already in the frame.
3) speedo cable - the COM has a screw-on cable - the C6 has a hole where a the speedo drive gear slides in. I assume i'll have to get a cable for the later C6.
4) drive line attachment. the COM has a flat plate on the trans that bolts to another flat plate containg the front U Joint. the C6 looks like the UJoint bolts right to the yoke. i'll have to get some U-joint bolts.
Question - should i swap yokes on the trannies or get the U-joint for the 72?
which ever is easiest
brainfart3
re: CruiseOMatic for C6 swap
anyone know what the torque specs are for that yoke nut?
sideoilerfe
Re: CruiseOMatic for C6 swap
Post by sideoilerfe »
The earler C6 have the screw in type. My old 70 and 68 have the screw in type.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
TommyG
Post by TommyG »
My COM just lost reverse....is the C6 a better tranny..? If not, pray tell, What is..???
c6 is the best auto ford made in these years. of course the c6 is in the com family. or its catergoized in the com family.
brainfart3
getting there... had to drill new holes in the frame for the trans crossmember - not a big deal.
however the bolt-on /2 piece driveline now seems to be a couple inches too long :o
i'm not adverse to drilling more holes for the driveline support mount - but the slip-in just doesn't seem to slide all way into the yoke.
must i cut off a couple inches of the splines to make this work??? :?
also - anyone have an extra kick-down linkage that bolts to the side of the C6? i have the kick-down rod - but trans linkage is missing.
trip to the wrecking yard yesterday proved fruitless
F-100Ranger
Post by F-100Ranger »
not to be disagreeable, but the FMX is a better tranny. It's a roller tranny with just as much strength as a C-6 and uses less HP
67 Austin Healey 3000- resto - subframe rebuilt so far
68 F-100 LB w FE410-in progress frame-off resto
02 Sebring Convertible- for top-down relaxation
i guess you could cut the end of the splines off. but i would just redrill the carrier bearing mount holes if you can. either option should work.
brainfart3
BACK ON THE ROAD AGAIN!!!!!!
issues:
1) had to drill holes in the frame to move the crossmember because C6 is 1.5" longer (2 drill bits @ $5 each)
2) shorten front driveline 1.5" so the center support could remain in the same location ($65)
3) new speedo cable - FMX had a screw-on end to the tranny - C6 had a slide-in unit ($20 at pick-n-pull)
4) adjust the linkage so P is P and D is D.
other than that - piece-o-cake!
a TON-O-THANKS for this website :fr:
BobbyFord
Post by BobbyFord »
FMX's are not stronger than a C6. FMX has a case design flaw that cracks the cast case when HP is applied. The case cracks at the band anchor.
