anything wrong with running a disk m/c with 4 wheel drums?
kilog55
Post by kilog55 »
the booster and m/c i got has the larger rear reservior so i assume it is for front disk rear drums can i use it? dont think there was anything wrong with the old one.
if there is a problem then maybe ill swap it on the 79 since i know i need a new one there
also i ordered the non adjustable brake rod on and the one they sent has the adjustable rod on it with the part that bolts to the pedal
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
montana_hiboy
re: anything wrong with running a disk m/c with 4 wheel drum
Post by montana_hiboy »
My m/c has the large rear reservior and it's on a drum/drum setup and my parts truck has the same m/c with large rear reservior and it's a disc/drum setup so i'm not sure it matters.
Jim
'75 Ford Highboy 390 4spd
heep70
Post by heep70 »
Front drums might lock up sooner and harder. The disk MC pushes more fluid to the front.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
ToughOldFord
Re: re: anything wrong with running a disk m/c with 4 wheel
Post by ToughOldFord »
montana_hiboy wrote:My m/c has the large rear reservior and it's on a drum/drum setup and my parts truck has the same m/c with large rear reservior and it's a disc/drum setup so i'm not sure it matters.
Mine too. It looks like it was a redesign to give the front brakes a larger reservoir, no relation to disc or drum use.
kilog55
Post by kilog55 »
welp i got er did after i put the brackets on wrong it was smooth sailing almost.
had to make a new brake line cause the new m/c that came with the booster i bought had a big hole and a little hole, well the lines i got from fordman had both big fittings so i had to bend a line but oh well not his fault they were oem so its bendix's new design that is/was flawed. i also had to remove every line and pull the dist. block off cause the old lines that i broke before were stuuuuck.
so its all back together and bled out and man she stops like a bike if you grab the front brakes.
sooo much better i just gotta get used to easing on the brakes now.
yea the new master should have came with the correct adapters to make those like fit it. sorry i should have sent the adapters with the lines.
kilog55
Post by kilog55 »
no problem man just gettin the info out there. i got it to work though so NBD atleast i could use one of the lines and got some practice bending brakelines
i have to bend a new line for my 93 it had one rust out. how did you bend yours?/ did you use any kind of tools? i have a conduit bender but i dont think it will work on a short bend for a brake line.
kilog55
Post by kilog55 »
i used a tubing bender it has 4 different grooves for diff size tubing the tight bends were hard i used my fingers as a guide similar to this one if not the same took alot of thinking to get the bends the way they were supposed to be
for the bends at the connections i left the fitting where it should be and moved up to the 3rd largest size but for small tight bends i used my fingers like i said. and they cam out pretty decent but not pretty by any means for the curls you have to bend it in stages or it will be as small as the bender part. just do it slow like everything important
