i have a 67 F100 with a 240
i know you guys know your stuff so here is goes. Well this two match up?
you might have to copy and past but it would really be helpful if some of you would check it out for me, thanks allot
http://www.jegs.com/i/TCI/890/511200/10 ... 6476|10559
http://www.jegs.com/i/B&M/130/80680/10002/-1
well this work???
re: well this work???
im also going to put a 302 in it in a couple of mounths so will that trans work with the 302 also.?
thanks you!!!
- MadMaxetc
Don't forget that the 300/240 has a slightly larger flywheel/flexplate and zero balance compaired to the 289/302. You can't just put 302 parts on a 300.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
