I swore I asked this question here many months ago, but now I can't find it.
I have a 31 spline 9" chunk that I got from a boneyard with a ratio that I would like to try on my truck. My truck has the usual 28 spline axels. Is it true that I can swap out the spider gears from my trucks chunk into the junkyard (ex 31 spline) chunk and use it? Are there any perils? Are all the spider gears interchangeable with all the cases? Is it straightforward? Or, should I just keep looking for an appropriate 28 spline chunk?
Rick
Switching Spider Gears on 9"
- Wes
if both 3rd members are same type you can, I would swap all 4 side gears and pinion idlers and maybe even the pinion shaft. Mark the gears so you can put them back in the same spots.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
re: Switching Spider Gears on 9"
Wes-
What do you mean by the same type?
The clusters in question are both 9" units.
One is the original one in my 67 F-100 (3.70) 28 spline
The junkyard one is I think a 2.75 31 spline that came from about a 1980 F-100.
Rick
Rick
