T-18 shifter
Jason
T-18 shifter
Post by Jason »
I have a 69 with a 300 and a T-18 transmission and my shifter now spins all the way around after i bumped it in the cold weather the transmission shifts fine if i can keep the stick straight enough to shift is this a hard fix (never pulled the top plate on a ford) I know when my old chebby did it. I just replaced a pin in the bottom of the shifter if anyone could tell me what part to buy and any other info would be great.
1967 F100 SWB step-side, 300" 6cyl, T-18 transmission and Dana 60-3 rear end with 3.54s
72hiboy4x4
Post by 72hiboy4x4 »
basically the same thing here...Just access the bottom of the stick, push down on the retainer, and turn until it releases. I sometimes have to use a pair of channel locks to get enough leverage to turn the retainer, but once its loose, the stick will pop right out.
No, you dont have to remove the entire top shifter cover to remove the stick....
Jason
re: T-18 shifter
Post by Jason »
thanks a million its really damn cold and anything to make it go faster is great
FLATBEDFORD
Post by FLATBEDFORD »
I cut a piece off a drill bit of the correct diameter to replace the pin on mine. I figured its pretty hard and should last another 37 years. Very easy. As I recall, all I did was remove the cover and slide a replacement pin in where the shifter pivots. I've probably made no sense, but once you take it apart, you'll see.
My Photo Gallery
averagef250
Post by averagef250 »
The early T-18's used a screw on shifter retainer, you don't push down and turn like a 435, they just screw off.
390Nut
Re: T-18 shifter
Post by 390Nut »
Jason wrote: I just replaced a pin in the bottom of the shifter if anyone could tell me what part to buy and any other info would be great.
You can buy them from Novak, only place I've personally found them, but if you send me a PM with your mailing address I'll send you one (I bought several of them and have one or two spares left). beats having to replace chunks of steel that have lost their temper when you cut them down.
8)
Paul
`69 F100 390 4spd driver
Jason
re: T-18 shifter
Post by Jason »
ok now does anyone have the top cover for a T-18 the place with the pin on mine is shattered and un-riggable
390Nut
re: T-18 shifter
Post by 390Nut »
ouch! That sucks man, sorry to hear it.
I'ld post up in the "parts wanted" section too. Might get better coverage there. :thup:
Paul
