3.70 rear end ratio
3.70 rear end ratio
How much torque can they handle. I know there not ment for SPEED. Ive herd nothing over 80 mph would be to smart.
- 72stepside
re: 3.70 rear end ratio
I have that ratio in the F100 coupled with the 3 speed and the 300-6. Pulling is not a problem. Racing and cruising at 80 on the interstate... well lets just say the ole 300 is wound pretty tight at those speeds.
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
Hedman Headers
Disc Brakes
- jzjames
3.70 not for hiway driving, when I do make long trips, I'm doing like 62-67 mph. but then I go pretty easy on my vehicles nowadays. Id bet these trucks are not seeing that much hiway driving anyway. I like the torque, driveability, and pretty good mileage.
- MadMaxetc
If you have a OD trans to help control the RPM of the engine I don't see what differance it would make to the rear end? Lots of racers use the 9" rear ends at high speeds in circle track racing...how would a nice smooth highway be any differant/worse?
I have 3.7's in may truck and drive 70 mph all the time. I have never had it get hot or had any problems. Just keep the fluid filled and the vent working and you should be fine.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
I had a 3.70 in my 71 back when it had a 351W AOD in it. Cruised the interstate well at 70-80. Sucked down the gas at those speeds though.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
