I have a floor mounted three speed manual transmission. Last night when pulling into the driveway I could not get it to come out of gear. It will drive all day in second, but I can't get it to come out of second. The clutch works when you step on it.
Any suggestions?
Stuck in gear
Stuck in gear
1970 Ford Boss 302
1972 Ford F100
Old Fords are like fine wine, they just keep getting better with age.
1972 Ford F100
- 19674x4
Try dropping the clutch in say 1st gear and pulling the shifter out. you may want to check the linkage to.
My Photo Album
I think that jammed linkage is probably the most likely cause; but,
if the pilot bearing is badly worn it will sometimes cause the clutch to drag a little. I know you said the clutch works, but it could be that the clutch is dragging just a little and keeping the trans loaded too much to come out of second (although not so much that it kills the engine).
re: Stuck in gear
Got it out of gear but now it shifts terrible
1970 Ford Boss 302
1972 Ford F100
1972 Ford F100
