Driveline length questions
mjhaltom
Post by mjhaltom »
I removed a 240 and a 3.03 and I am installing a 390 and a T18. I know I can reuse the rear section of the driveshat, but will there be a difference in length in the front section?
Also, does the transmission crossmember need to stay in the same place? I already moved the engine perchs to the back holes.
Just rying to eliminate as much trial and error as possible. Thanks
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
tybob81
Post by tybob81 »
I thought the I6/fe perches mounted in the same spot. If you only moved it back an inch or less you shouldnt have to cut the front drive shaft section down.
1968 swb hydroboost, ididit tilt column, Saginaw p/s pump with F series serpentine, all led lights, Vintage Air and painless wiring. 393w, tko600. CV front suspension w/c5 calipers and gt500 rotors. Stock Flexomatic leaf springs with 01 CV 8.8, 3.90 gears and Auburn locker. Custom wood bed floor. Full frame off resto-mod.
normally when you change from 6 cyl to fe the perches are moved back to the back set of holes. as far as driveshaft length. i dont know. i have never even seen a t 18. what i would do is measure the three speed from the bell housing to the rear seal . and then measure the t18 the same. figure the difference and then figure where you are from there. there is a little give on the carrier bearing mounting on the frame where you can redrill the mounting holes if you have to to make your old shaft fit.the easiest way to find out length would be for someone with a similar setup is to measure what there driveshft measures. i dont have that so i cant help im sorry.
