axle assembly
axle assembly
I got all the nuts and washers off the rear end and it losend up. The problem now is it wont slide out. Anyone know a good way of pulling out the assembly?
Camel Ciggarettes,John Deere and Ford "Hard To Beat"!!!!
- MadMaxetc
Are you talking about a 9"??
If you are then yo need to pull the axles out before you can pull the pumpkin out.
If you can't get the axles out you can losely bolt the drum on backwards and use it like a slide hammer.
The pumkin is heavy so be carefull.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- MadMaxetc
Just did this on my 67. My pumkin was realy stuck on, when it came off I almost droped it on my foot!
Dan
FORD Girl
FORD Girl
