Saturday I am going to get a decent grill off of a 68. The truck is off to the crusher
Anything I should make sure I take with me to get it off in one piece?
Mike
Grill Removal. Special Tools???
- 1968Ranger
re: Grill Removal. Special Tools???
PB Blaster and spider spray
Assuming it is essentally the same as a 70-72 it is pretty easy and is held on by only phillips screws and (IIRC) 1/2 bolts.
- fordtruckparts
Just be careful not to break off any mounting tabs. They are extremely brittle. You must have a lot pf patience otherwise something may get broke. The bots are usually rusted right to the clips, leaving the grille right in the middle of all the wrenching. This is how the mounting tabs can be damaged. If possible, undo the bolts from the inner fenders, and then just unbolt the upper valance panel (the one the lower hood latch clicks into), and remove it still attached to the grille. Lay it on the ground and remove it. This will save you a lot of frustration, and save you the skin on your knuckles. You may find a zip cut handy as well, should you run into some really stubborn bolts
Hope this helps; good luck!
1948 Dodge 2.5 Ton, 1959 International Harvester BC-180, 1959 Willys Pickup, 1965 Impala HT, 1965 Galaxie Convertible, 1967 Mercury M-100, 1969 F-250, 1971 F-250, 1976 F250, 1978 F-350, 1979 F-250, 1980 Dodge D-300, 1984 F-250, 1986 F-150, 1987 Chevy Monte Carlo, 1988 F-150, 1988 Mustang, 1990 F-150, 1994 Camaro Z28 LT1
- lobuck76
A 1/2" wobble socket and about a one foot extension is pretty handy for the bolts that are at the top inside of the fender.
And I second what fordtruckparts said about the valance panel. Buy it if you have to and take it off when you're not in a hurry . The frozen up bolts and j clips will tear up the grille.
'71 F-100
- 1968Ranger
Thanks Guys I have the PB and the extensions. Will hopefully(weather permitting) have a new grill tomorrow.
- 1968Ranger
Oh well,
The grill had a cut in the aluminum so I let it be.. But I did get two F-600 Clusters for $20 while I was there. Not a total loss.
Mike
Mike
