Another one of those rear end gearing questions!
- mrtleavitt
I just put a T19 transmission in my 1972 F100 with a 390 and I love it! It has a 4.02 first gear in it which is just a hair too low for my liking but I can still use it because it's not a super low granny gear. Fourth gear is still a 1:1 but I would like to gear it up just a bit. The truck is a sporty in-town truck that sees the freeway every once in a while. I never ever haul anything, I just zip around town with it. I don't want to go too high because then I can't get a good start off the line. I have 4.10 gears right now. I was debating 3.50 gears, or would 3.70 be a better way to go? I think 3.70 won't do enough to make a big difference. What do you all think?
- AlleyCat
re: Another one of those rear end gearing questions!
I've had 3.50's behind a 390 in a dent and think they work well.I'm probably going to go that route when I put the 390 in my 72.
Clay
I'd have to agree with the 3.50s, if you're not planning on doing any heavy towing. It'll probably bump your mileage up at least a few points too.
- 390Nut
Another vote for a 3.50 ratio. With my T18 and 3.50 gears, I'm pulling roughly 2400 RPMs at 65, and it has plenty more to go. Mileage isn't the best, but mostly due to the engine I built, and how I drive it.
Great for git-up-n-go, and works for towing in a pinch, or occasional light duty towing if you don't want to mess with swapping gears.
Paul
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"
- mrtleavitt
Thanks guys, I think you've all talked me into 3.50s. Sounds like the way to go with those old 4 speeds.
