Stock or 2000rpm stall for C6 rebuild?
HOWDY69
Post by HOWDY69 »
I am having the C6 rebuilt. Should I go with a stock or 2000 rpm stall converter? Dailey driver, not much towing. Melling MTF-4 cam.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
averagef250
Post by averagef250 »
NO way, a stall converter will make you want to kill in your daily driver or towing. They turn your gas pedal into an on and off switch.
re: Stock or 2000rpm stall for C6 rebuild?
With that cam I'd just keep the stock one.
:2cents:
