fuse box
Electrical and Wiring Forum Archives
shortbedCUSTOM
fuse box
Post by shortbedCUSTOM »
anyone have a diagrahm of the fuses and fuse box? I need to know the amperage of each fuse and what it does. I was installing my radio yesterday and I managed to burn a few. :oops: I forgot to disconnect the batt. :x
I removed the burned fuses and they have no marking on them as to the amperage.
thanks for any help provided.
Carlos
jor
re: fuse box
Post by jor »
Here's what mine looks like.
jor
bluef250
re: fuse box
Post by bluef250 »
for a 1968 from owner manual diagram
Top - heater - 20 amp
next down - back up lamp, turn signal and w/s washer - 14 amp
next down - Instrument panel lamps - 2 amp
btm left - dome lamp and cigar lighter - 15 amp
btm right - emergency and stop lamp - 20 amp
shortbedCUSTOM
re: fuse box
I guess I should of mentioned that I have a '70 model.
jor, mine looks nothing like that.
bluef250, it sounds like yours run up and down. mine look to be a little scattered around the box.
bluef250
re: fuse box
Post by bluef250 »
Basically a square fuse box. top 3 spaces are singles. Btm spaces are in tandem. I added photo's of two fuse boxes and page from owners manual.
