averagef250 wrote:That's not bad at all then if the input's in the same spot. The pics make it look lower than stock I guess.
I'm talking about the actual angles of the U-joints in the center driveline. The angle of the driveline has no bearing on anything. U-joints have to be phased and angles need to match. Stock highboy center driveline U-joints are 3 degrees for a manual and 4 degrees for a C-6.
Rotating the t-case in the same plane as stock means it's angle didn't change, so the factory front pinion angle is ideal if U-joint angles aren't maxed out. If you're switching to a HP60, the 60 has the pinion "up" to the same degree as the low pinion is pointed down. You can't change the angle unless you go to a CV front driveline otherwise your U-joint angles won't match.
With a HP60 and the divorced case, even rotated up, and just a 3" lift, raising the front pinion is going to make things worse I'd think.
Schedule 40 pipe, Gotcha.
Yes, and sorry I left something out, as you said.. the d60 is a HP. I still may modify the d60 angle very slightly because my front hanger and rear shackles are not stock. The longer rear shackles up front caused the dana 44 pinion to actually point down, the HP will help it move up, but I cant say if I will have to change it until I get it.
If you dont understand why the front angle is point down,and why I may have to modify the HP60's pinion think of it this way.
When you buy a lift kit for the f250, they give you lift springs, the stock shackles and hanger stays in the same place.... I made longer shackles and a new front hanger (the shackles actually gave it more lift than the hanger did which is my mistake) so that the longer the rear shackles are the more the axle will face down, if you have shorter shackles, the pinion will raise up.
