my mom just bought.....
Nickabocker
Post by Nickabocker »
ok my mom just bought me and my brother a Isuzu rodeo. she came home and told me the only thing i need to replace is a carrier bearing.......now my question is what is this bearing and where in the read end (if thats the spot) is it located..... i've tried searching on the part store sites but for some reason i can't find one does it go by a different name or what?
nick
71PA_Highboy
re: my mom just bought.....
Post by 71PA_Highboy »
The carrier bearing in usually a bearing that support the middle of the driveshaft... and the Rodeo doesn't have one IIRC...
Find out what is really wrong and maybe I can help more.
Good Luck!
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
gmcjimmy88
Post by gmcjimmy88 »
Yeah a rodeo should not have a carrier bearing unless it is a newer one that is a bit longer wheelbase, maybe. ould have meant the bearing in the carrier of the rearend? Good luck and keep us informed and should be able to help you out.
[quote="MOST OF ALL, pray about it. If God doesn't want you to go, he will make it clear.[/quote]
1967 F-100 Longbed (project truck) For sale $1200 http://www.fordification.com/galleries/ ... ?album=710
http://www.fordification.com/galleries/ ... ?album=726
1990 Blazer (offroad toy) 7 in. lift, 37 in goodyear MTR's
2000 Ford Focus (DD/commuter car) ABOUT TO BECOME TARGET PRACTICE!
2005 GMC 2500HD Ext. Cab Longbed (Towrig for the blazer)
2006 Kaufman 20ft steel deck car hauler (The only way the Blazer sees the road)
Nickabocker
alrighty thanks i'll check it out and get back to this in a bit :) thanks again
nick
Nickabocker
what you mean by the bearing in the carrier in the rear end.... its a 1992 rodeo
nick
averagef250
Post by averagef250 »
Rodeos are bad news. 1/2 the parts aren't made for them anymore.
