Booster Brackets??
Booster Brackets??
Up till what yr. will the booster brackets fit my 67??
Camel Ciggarettes,John Deere and Ford "Hard To Beat"!!!!
- td
re: Booster Brackets??
if you are doing a power brake conversion all you have to do is buy your self a 73-77 booster master kit they come together. mine was $119 78&79 wont work with our trucks. then you can find a donor of the same year and get the booster brkt.
- Supermike
Keep in mind the '67 has a different length push rod, due to the different brake. So if you don't have a booster with an adjustable push rod, you'll have to be sure to get one from a '67.
The bracket itself should be able to come from any 67-72.... and maybe later. Perhaps Keith can confirm?
Former owner of a '67 F100 Camper Special
Current owner of a 2022 Ford Bronco Wildtrak
The '67 is a one-year-only item. I'd highly suggest finding a '68-'72 donor truck and swiping the brake/clutch pedals bracket. Then you can use any '68-'77 power booster. As mentioned, don't get one from a '78-'79.
See the following link for more info:
http://www.fordification.com/clutch-brake-brackets.htm
