HELP I'm stuck
mont974x4
HELP I'm stuck
Post by mont974x4 »
I can't get the beast out of 4wd. I can't get the hubs unlocked and I can't shift the xfer back into 2wd. :x
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
heep70
re: HELP I'm stuck
Post by heep70 »
The case is gear driven, they can get mean if they get bound up. Get on some level ground and let it free role backwards and move the selector. You might have to let it free roll forward and move the selector.
Mine give me crap also, espeacially when I try to unlock on pavement.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
mont974x4
re: HELP I'm stuck
Post by mont974x4 »
I tried the lettin it roll back and forth trick before I posted.
I had to pop the cluth and bark the tires a bit :evil: but she slipped into 2wd. what a pain. Would changing the fluid help?
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
heep70
re: HELP I'm stuck
Post by heep70 »
No, I would check the fullness of the fluid. That sounds a bit drastic when you have to bark the tires. Another trick I have used is to turn the tire back and forth while rolling. I had to do that a few times after I put lockers in. If the selectors on the hubs are tough then that means the center is bound up.
Does this happen every time? Try it again and see if it continues.
You can also shift these on the fly with the clutch in. Note: from 2H to 4H and back. You can not shift on the fly to 4L or out of 4L.
Greg
mont974x4
re: HELP I'm stuck
Post by mont974x4 »
This was the first time its happened.
:lol: The tires only barked because I popped the clutch on accident. I read your idea and just threw some slippers on to go try it and my foot slipped.
BTW I have a dana spicer xfer (according to the tag) and it only has 2wd and 4wd no 4hi or 4low.
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
Faithful Old Road Dog
re: HELP I'm stuck
Post by Faithful Old Road Dog »
The F100's have Dana 21 t-cases. How far are you rolling back. Sometimes I've had to roll back at least two truck lengths to get the hubs to unlock.
heep70
re: HELP I'm stuck
Post by heep70 »
Sometimes you need to take a few added steps to get these old rigs to cooperate. You have a single speed T-case like F.O.R.D. mentioned.
Greg
Rockcrusher
re: HELP I'm stuck
Post by Rockcrusher »
Mine got all bound up a couple of months ago but I took the easy way out . . . Got out the floor jack and lifted the front wheels off the ground.
Rockcrusher
http://www.rockcrusher4x4.com
Ignorance is sticking your hand in the fire 'cause you don't know what it is ... Stupidity is doing it a second time.
mont974x4
re: HELP I'm stuck
Post by mont974x4 »
I rolled back a fulll truck length on one attempt.
Jay
72 F-100 4x4
97 F-150 SCAB 4x4
