Photo Request: transmission linkage
I was hoping I could see some pictures of a colum shift, c6 linkage. I want to try and fabricate it but, I have no idea where the exact placement of the pivot and its mounts. thanks
kyle
1971 F100 2wd swb 429 C6
re: Photo Request: transmission linkage
do you need the rod that goes from the colum to the side of the trans.
You must have the linkage that has the bell crank set up. I have mostly seen them in the 80's model trucks if I remember right.
I don't see why you could'nt go to just the one rod set up though
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
ok, see i have never seen one from a 67-72 f100. Only late model 77-79's. I'd love to see the one rod setup.
kyle
