3 spoke steering wheel on a 71 or later column
Seems like I've read somewhere that the 71+ columns are different at the area where the steering wheel mounts, making it hard to use the earlier 3 spoke columns. Is that true? Any one been able to get it to work and look right?
re: 3 spoke steering wheel on a 71 or later column
All you have to do is grind off the nub on the end of the '71-'72 steering shaft, for horn button clearance.
Will the horn then work as before?
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
- averagef250
Or, If say you're you're a little slow like me and already put the 3 spoke wheel on the '71 column and tighten the nut before you figure out they're different, you can holesaw a hole through the metal plate on the rear of the horn button!
You cut a hole up thru the horn ring? Pic's!
Just gonna put a 67 wheel on my 71 too. I was gonna get the plastic
thing that holds the horn ring on. 7.00$ + 12.00$ S&H. Cute. It would
fit in a envelope. Why is it these "enthusiast" suppliers try to SCxxW
everyone?
DC,hope you read this forum time to time.
everyone?
- MadMaxetc
Re: re: 3 spoke steering wheel on a 71 or later column
Hey would you want to traid that 67 for one out of a 79? I would like to have a 60's style wheel on mine.Jake11 wrote:You cut a hole up thru the horn ring? Pic's!
everyone?
Dan
FORD Girl
Photobucket Pictures
FORD Girl
The bumpside-era steering wheels won't fit on a '78-'79 column. I tried with a '68 wheel on a tilt column. I don't know if the '73-'77 columns are different though.MadMaxetc wrote:Hey would you want to traid that 67 for one out of a 79? I would like to have a 60's style wheel on mine.
Not only does the bumpside wheel have a smaller hub:
...but the bottom of the wheel has some nubs on it that interferes with the column:
- ezernut9mm
jeez man. s&h is killer. through lmc the "horn retainer plate" is 4.95. i could buy it and ship it actual cost if you really want one.Jake11 wrote:You cut a hole up thru the horn ring? Pic's!
everyone?
Does someone know this?mjhaltom wrote:Will the horn then work as before?
1989 Ford F150
1989 Ford F150
- MadMaxetc
Keith, I have a 67 column and 2 70's style (2 spoke) wheels. I want a 60's style (3 or 4 spoke) to put on.
I thought the 70's took the 2 spoke wheels?
What where the cut off dates?
Dan
FORD Girl
FORD Girl
You said you wanted to trade for a '79 wheel, I assumed you had a '79 column and wanted to put a bumpside wheel on it, so I was alerting you that it won't swap over. All the wheels from the bumpside era are interchangeable, as long as you grind off the shaft end on the '71-'72 columns before trying to mount an earlier wheel.
I tried to put Dotcentral's 3 spoke wheel on to a 73-74 column. Once I tightend it down it bound the steering wheel up where you could'nt turn it.
I looked at everything I could think of but could'nt tell where it was binding at.
He has a 71 style wheel on for right now.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- MaxKlinger
Will the steering wheels from any of the Ford passenger cars of the 67-72 era also interchange with the trucks? The wheel on my 72 looks gross and I'm looking for an earlier-style wheel to replace it. Just curious to see if a passenger car wheel from the late '60s was too different.
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
- occupant
I have another possibility to ask about...
1971-1972 column with 1971-1972 wheel. That works. How about the 1971-1972 column with a later model wheel, the one used from 1975 on with downswept spokes, I think they used it through 1991 in the Econoline vans and 1986 in the F-Series pickups. I see a lot of them on vans in junkyards and it's what I put on my '75 Torino when I couldn't stand the duct tape covered stock wheel anymore. That wheel came off a 1989 Econoline.
Alan Moore | TOAD Towing | Columbus, OH
00 Suburban "Moose III"
Strong Bad I | Strong Bad II | Strong Bad III
