what transmission do i have?
- mr.skaggs
i got a t-19-148 and it has a tag on it with 428115-c91 would like to know if its a good type for 1 ton thnx
i have a '69 f-250 camper special that im putting back to orginal condition.it is taking a long time to do but it is my hobby..this website has been of great value on looking for the correct parts and i have came across a very good way to remove rust from parts without damage to the part ..it takes time but no abrasives to wear off the numbers or castings!!
- averagef250
t19-148 is just the BW part number for the top plate. You probably have a 4.02 first ford T19. They're a good tough tranny, but don't have a granny gear. Don't use this transmission unless you have tall rear gears and do not need granny.
- mr.skaggs
re: what transmission do i have?
ok thnx it also says muncie on side of case and has 2 pto plates on it..one on each side. so it's a good trans,but no granny gear right?
- averagef250
Muncie is a division of GM powertrain. The T19 is made by Borg Warner. A T19 should not have anything to do with muncie cast into it.
They're bulletproof. It may have a granny, but more than likely not. There are three different first gear ratio ford T19's. Most of them are the close ratio 4.02 first transmission. You can very simply count the input turns to one turn of the output in first gear.
