Someone wanna count their teeth?
- jdconnel
Wondering what the proper speedometer gear teeth count should be for a 3 SP NP-435 transmission. Truck has a Dyna 60 rear end with a 4.10 G.R
I know I asked this once, and was told to “order a few teeth lessâ€Â
-=Life's Too Short to Drink Cheap Beer=-
1973 F-100 Custom Sport (Previously had 1967 & 1970 F-250)
- averagef250
re: Someone wanna count their teeth?
- jdconnel
Ok, here is goes…..
I have the original rims (16.5's). I think I have 8.75LT16.5 tires on the truck... going by memory. To, transmission, tires, and rear end are all factor original specs.
I found similar tires listed as 225/50R16.5 (gives me my .5 aspect ratio, unless you have a better number)
Section Width: 8.75 in
Aspect Radio: 0.5
Rim Diameter: 6.5 in
Tire Diameter: 25.25 in [2 * (8.75*0.5) + 16.5]
*Note: number feels right from when I’ve had a tire off….
Tire Circumference 79.3 in
Tire Rev. per Mile: 798.7
# Drive Teeth: 28
Drive gear refers to the gear that is on the transmission output shaft. Based on the transmission section "28-spline output shaft"
Axle Ratio: 4.10
# Driven Teeth = 91.6 (based on the math):
(# Drive Teeth X Axle Ratio X Tire Rev. per Mile) / 1001 = # Driven Teeth
“The driven gear is located in a removable housing usually in the tail housing of the transmissionâ€Â
Aspect Radio: 0.5
# Drive Teeth: 28
Axle Ratio: 4.10
- spartman
I think that for the tires you have the aspect ratio should be different.
I know that the older style tire sizing had more sidewall to tread, whereas the 50 series P-metrics have more tread to sidewall thereby affecting your aspect ratio.
If I were you I would use a tire that has a sidewall ratio of either 75 or 80/85 from a P-metric tire.
- 19674x4
3-spd np-435, are you sure. it's a 4speed.
My Photo Album
- jdconnel
- kaptnkaos
Hey JDC...
I just counted mine ... none ....
KaptnKAOS
KaptnKAOS
- jdconnel
Re-ran my above calculations with # Drive teeth = 7, kept my ratio at .5, and the answer is 22.9.
I am basing the “7â€Â
- MadMaxetc
I think you are making it more complicated than it needs to be.
Since your RPM, Tire Size, and Gear Ratios are all the same it is just a matter of simple Ratios.
You say that at 60mph (tailing a buddy going 60?) you are reading +15mph, so 75? If I am understanding this right then...
with an 18T gear, 75mph/60mph = 1.25.
1.25*18 = 22.5T (ideal)
A 22T gear will make you read a little fast.
A 23T gear will make you read a little slow.
The only problem is that they only make a 21T at moset.
What gear do you have on the cable? You may have to change that too.
Post that and I will re figure.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- jdconnel
There's a gear on the cable too? Like behind the dash?
Don't know what that one is.
If you look at that link I posted though, it mentions a 23T gear for use with 4.10 ratio... which is what I have.
I'm going to run a GPS and drive to get my speed to speed conversions figured out for sure. Should be linear.
And yeas, buddy tailing me at 45mph. dash read 60.
- MadMaxetc
There is one in the Trans (18T to 21T I think) and there is one on the end of the cable that plugs into the Trans (16T to 19T I think).
Dan
FORD Girl
FORD Girl
