Rear leaf springs
TheeMc
Rear leaf springs
Post by TheeMc »
My F-250 Camper Special, has the original rear springs (as far as I know). I use it to tow a travel trailer with a 900lb tounge weight, it sags down pretty good. I have the load leveling hitch and all, but was thinking of "Beefing up" the rear springs by putting on a set from a one ton. My question is what years will fit with out making welding mods? Has anyone done this before? and are there better, easier options that I wont have to re-mortgage the house for? Also on that same line how do I figgure the towing capicity?
Thx!
M
TheeMc
72 F-250 C/S
Why do we drive on a parkway, and park on a driveway?
"98% of all Dodge trucks are still on the road;
The other 2% actually made it home..."
mjhaltom
re: Rear leaf springs
Post by mjhaltom »
I was thinking of adding a helper spring . I was told you could get a universal one at your local parts store. :2cents:
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
72hiboy4x4
Post by 72hiboy4x4 »
I put 1 ton springs under my F-250 4x4, and used a Dana-70 dually rear axle also.
I think, (for the 4x4's anyways) that springs from a F-350 from '67-72 should work. My donor truck was a '71 2wd F-350.
I had to get new u-bolts to accommodate the 4" lift blocks on the Hiboy suspension, but other than that, they bolted in.
see this thread for a recent discussion and pics.
http://www.fordification.com/forum/view ... highlight=
averagef250
Post by averagef250 »
I think the F-100's and 250's use a different spring setup than the 250 4x4's and F-350 2wd's.
