POLL: Tire Size
- Zeke71250
POLL: Tire Size
I did a Forum search for "poll" and didn't see this one - although the question is asked a lot.
re: POLL: Tire Size
12x16.5's Yes they still make them. Got a like new set of 10" wide
rims, but I think they'll tear the front fenders off.
Any one tryed 10"s on the front?
- ezernut9mm
Re: re: POLL: Tire Size
you got some gravel to pack down or somethin'?Jake11 wrote: Got a like new set of 10" wide
- crash_552
re: POLL: Tire Size
44's on mine. As soon as the new suspension goes on I don't think I'll be gettin in without a step stool!!!
Good judgment comes from experience... and a lot of that comes from bad judgment
http://www.fordification.com/galleries/ ... ?album=731
- 68F250
re: POLL: Tire Size
9.50R16.5 front
33x12.50R16.5 rear
33x12.50R16.5 rear
Barry
- Zeke71250
You know, I think Sharkdance has 15x10's on his F250... with 31-10.50x15's.Jake11 wrote:12x16.5's Yes they still make them. Got a like new set of 10" wide
http://www.fordification.com/forum/view ... ht=tire%2A
- Zeke71250
The 2" offset ones, were those the chrome smoothies?ezernut9mm wrote:i ran 8's on the front with a 2" offset and the fatcory off set is around 3.5 or 4", so i guess they would work with the stock ride height. better get a steering damper though.
Were the front and rears the same?
- Zeke71250
Barry,68F250 wrote:9.50R16.5 front
33x12.50R16.5 rear
What's the size and backspacing on your rims? Are they the same size and offset all around?
Just wondering.
- 68F250
re: POLL: Tire Size
I'm pretty sure the front rims are 8.25" wide and the rears 9.75" wide. As far as everything else I can't remember, will have to measure.
Sorry.
Sorry.
Barry
- Zeke71250
No big deal - just curious is all.68F250 wrote:Sorry.
- ezernut9mm
yes, and yes. the track width is wider in the front so a 7" with factory offset in front and the 8" with the 2" offset in the rear make the tires track the same width, or close enough that it looks better.Zeke71250 wrote:The 2" offset ones, were those the chrome smoothies?ezernut9mm wrote:i ran 8's on the front with a 2" offset and the fatcory off set is around 3.5 or 4", so i guess they would work with the stock ride height. better get a steering damper though.
- Rockcrusher
re: POLL: Tire Size
I dunno what factory size is but I normally run 30×9.50/15 on 7" wheels on all 4 corners of my SWB 4×4.
If I'm going out to play in the desert, I'll sometimes swap the 33×12.50/15's on 8" wheels from my Jeepster . . . They air down a lot better.
Rockcrusher
http://www.rockcrusher4x4.com
Ignorance is sticking your hand in the fire 'cause you don't know what it is ... Stupidity is doing it a second time.
- Zeke71250
Now there's some new info for me to chew on... Thanks!ezernut9mm wrote:the track width is wider in the front
The "wider in front" look is not something I'm fond of... it only looks good on a forklift.
re: POLL: Tire Size
40 inch ground hawgs with 12 x 16.5 wheels. 3 inch body lift no susspension lift, sawsall to all wheel openings.
http://www.fordification.com/galleries/ ... ?cat=10578
Engage Brain BEFORE Engaging Gears
72 F-250 390, NP435, Dana 24, D60, 14b, 4.88s, detroits, 2 winches, 4x4 40" tires.
re: POLL: Tire Size
Do I get to reply for each truck I have?
Doug
