I forgot to look this up at home, can someone help me out with a part #?
What is the Ford part # for the clips that hold the long narrow stainless moulding on to the tailgate. Not the piece that reads F O R D, but the piece below that.
thanks in advance.
need an answer fast!
- 68F250
re: need an answer fast!
Trying to be fast here, I believe it's C7TZ-99407A12-C, it takes 7?
Thanks. That was pretty fast. I'm on a tight schedule today & don't have time to run home and look it up.
Do you remember, are the they rivet on type or the nut-bolt type fasteners?
- 68F250
Those are the ones that take the rivets, is that what you're looking for?
My 1970 assembly manual shows a slightly different part #. C7TB-99407A52-A. It does need 7 and is riveted to the tailgate. The place I went to the guy couldn't find it under your part #. Don't know if he would find it under mine either. I'll just go to Dennis Carpenter's and buy them there.
I agree,# C7TB-99407A52-A .You'll need 7 of the plastic rivet type,and two for the ends.These are metal type.which bolt through the ends of tailgate.
1968 F-100 Custom Cab
300 6cyl 4spd
If it ain't broke,what the hell, fix it anyways !
300 6cyl 4spd
- 68F250
Sorry about that, must have read it wrong trying to be fast.
Thanks for the replies. All that trying to be fast didn't get me anywhere, did it? At least we tracked down the part #.
