The clutch works fine for about two hours and that means two hours of use or scattered 30 minutes of driving.
After two hours the clutch starts grabbing and just backing into my space at home to stop the hopping I rolled forward and dropped the hammer in reverse to get it to roll back into the spot spinning my tires.
It was jumping so bad the truck was breaking the tires loose anyway and it was moving sideways with all the hopping. So I took the easy way out.
Any clues or places to look? In all my years this is the weirdest clutch or drivetrain problem.
Relp Wierd clutch prob
- 67highboy
re: Relp Wierd clutch prob
I have had a clutch get really grabby like that when they were hot.
It was on a 78 150 4x4, I eventually took it apart after I twisted the pinion in two on the 9" to see what was up, and to possibly change the clutch and found that the input shaft seal on the NP435 was puking gear lube out, It wasn't enough to soak the clutch but it was just making one side of the disk damp.
I don't know if thats your problem but it took care of mine.
John
John
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
Ben Franklin 1775
Sounds like oil getting on/in it.
- cooltoolguy
interseting. mine hops bad when I try to reverse with a load on it. bad enough that the fan actually cut the upper radiator hose in half
probably oil from the engine, tran and other unknown sources.
72 Ford F-350, 2WD, 4 speed 360, Dump truck
76 Ford F-350, 2WD, Cab and Chassis <--gone
- ICEMAN6166
could be oil as suggested, other things involve heat, input shaft getting hot and or is loose and disc is getting stuck on it, either input shaft bearing or pilot bushing or both.have had pressure plate bolts get loose before too, any jamming from off angle or heat traveling from shaft to disc thru the metal can be the cause.
- two-bit
If thats bolted up to an FE block... check the freeze plug that they install to seal the cam bore. I had one start to leak and it splashed oil all over the back of the flywheel. After a certain amount of time, the flywheel splashed it on to the pressure plate and disc. Caused me to have a jumpy/grabby clutch too!
Just a thought.
Two-bit
Just a thought.
Two-bit
- ICEMAN6166
Re: re: Relp Wierd clutch prob
i had one some moron put in backwards.i know the shop that did it, would never take anything there but some people still do and always have problems.two-bit wrote:If thats bolted up to an FE block... check the freeze plug that they install to seal the cam bore. I had one start to leak and it splashed oil all over the back of the flywheel. After a certain amount of time, the flywheel splashed it on to the pressure plate and disc. Caused me to have a jumpy/grabby clutch too!
Just a thought.
Two-bit
