Hey guys, I have tried to do my homework on what I need as far as a clutch kit, but I must admit I am not sure which one I need. I have my old one so I went out and did some exact measurements on widths, so here goes:
Friction disc - 11 3/4" across the disc in the center.
Pressure plate - 11 7/8" across the plate center.
The only numbers I could find on the pressure plate are: LC0080 7K 27B
My engine is a 390 and my transmission is a New Process 435.
So, I have seen that there are 11", 11 1/2", and 12" models. I was wondering which one of these mine fit in...
Thanks much in advance!
Oh and I am sure the 11" one is out because I e-mailed about this one http://cgi.ebay.com/ebaymotors/Clutch-K ... dZViewItem and it was not the right one.
Clutch Kit specifications needed!
- ICEMAN6166
re: Clutch Kit specifications needed!
i would have to go measure the discs i have,but i would guess you have the 12"
also, i never heard of 11 1/2", only 11" and 12"
- 68swb
i am pretty sure that with a 390 you will need the 11.5 disc, that is what i have read somewhere maybe it was here i cant remember but i know i have read it, and the 11 inch is for the 360.
"I got this"
68 swb 429ci 3spd
69 lwb f250 360 4spd
75 VW superbeetle
79 F250 4X4 supercab 400 4spd
07 Fusion
08 Focus 35mpg
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
- ICEMAN6166
Re: re: Clutch Kit specifications needed!
its the size of the bolt pattern for the pressure plate on the flywheel that matters,not the engine.the FE flywheels fit all the FE engines and you could have either one, and it could have been changed somewhere along the life of the truck.68'swb wrote:i am pretty sure that with a 390 you will need the 11.5 disc, that is what i have read somewhere maybe it was here i cant remember but i know i have read it, and the 11 inch is for the 360.
Ok, did some research and it seems for my application, I need the 12" version. http://cgi.ebay.com/ebaymotors/NEW-CLUT ... enameZWD1V
this is the one for my application.
