Mitchell HD overdrive unit
- bigman78
Working on the truck today and had a guy stop by and offer me a Mitchell HD overdrive unit. He said it was something like 28%. He said what the 28% meant but I dont remember. It would turn my 4 gears into 8. He said he pulled it out of his old 74' before he sold it. Said it was the heavy duty ones they use in motorhomes. He also offered me a set of traction bars for the front. All for $200. Which to me sounds like a good deal. Said it was fairly new and that the overdrive cost over $2500 when he bought it. Does anybody know where I can find out about these mitchell overdrive units?
- 72hiboy4x4
- bigman78
re: Mitchell HD overdrive unit
Didnt get any pics of it it was at his house. I want it I just wanted to know a little more about it before I buy it.
1967 F-250 4X4 Highboy, 429, D60 rear, D44 front, NP435 trans, Dana 24 T-case, PTO winch
http://profile.myspace.com/index.cfm?fu ... =136460833
http://www.fordification.com/galleries/ ... ?cat=10577
- 19674x4
basically it is a gear splitter. you can put it od in high or lo, and then shift your regular gears. so, say you are just cruising down a flat road, you could put the od in high or engage it, and you would be in OD, but if you came to a hill, you would shift it into lo, and you would be out of OD and in regualr 4th gear. same thing with say 1st gear. You don't want such a low gear ratio, just shift the OD into high and bam you got a higher ration, or you want a lower ratio, shift it into lo. Another member put one similar to this in their truck and have a post on it somewhere on here.
My Photo Album
