auto tranny in a 300 straight 6?
jreb333
Post by jreb333 »
can it be done? what trans is best? what trucks / cars came equipped with 300 / auto? (so i know where to start my junkyard crawl) does the 300 bell housing pattern and depth match any of the V-8s?
this will be in a '67 1/2 ton longbed
thanks for the help
JESUS LOVES YOU! everyone else thinks your a jackass!
FoMoCo
re: auto tranny in a 300 straight 6?
Post by FoMoCo »
The straight six bell housing is the same as a 351W, 302, etc. I think AOD automatics came with the 300's. That may be computor controled, I dont know. I installed a 300 with a new process 4spd and had to change nothing. Trans mount was even on the mark.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
NM5K
Post by NM5K »
I'm not sure which one they used in 67..."c4, c6" ?? But would probably be the same as if it were a car...The old galaxies that had 240's often had auto trannies...Probably the most common example for that vintage...I once knew a guy that had one...65-66?? Actually drove pretty well, and was smooth... You couldn't hardly tell if it was a six, or a small V8, unless you knew the sound to look for. But yea, as one mentioned, the bolt pattern is the same as the 302, 351, so units workable should be a dime a dozen...Yea, an AOD would work too..All you have to do is rig up the linkage for the carb, and you can get kits for that I think..
MK
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
NM5K
Post by NM5K »
I think AOD automatics came with the 300's. That may be computor controled, I dont know......
The AOD uses a carb linkage...No puter...So it can be rigged up pretty easy, and I think they sell kits for this. The EAOD *is* puter controlled, and would be a bad choice, unless you wanna spend the $$$$ for a tranny puter...
I would bypass those....BTW...From what I hear, the linkage on the AOD *MUST* be set up correctly, or you can ruin the tranny...So you have to make sure it's right...MK
Ford_Doctor
Post by Ford_Doctor »
The AOD would be the hot setup. As stated earlier the AODE is computer controlled but the computer is not seperate, it is built into the engines PCM. Additionally while the bellhousing will bolt up to the 300 fine the trans x-member will need to be fabbed, and possible driveline mods.
willowbilly3
Post by willowbilly3 »
I am not sure on whether the 300s came with a noncomputer aod, but one from a 302 or 351W should work fine with the right converter. Most of the earlier 240/300s probably had a C4 which I think would be the best choice. I have seen some C6s behind 300s, mostly in Econolines but that is too much tranny for a 300, it will be happier with a well built C4.
But keep in mind that the overdrive probably won't get any better milage. The later EFI versions with overdrive don't get any better milage than the earlier carburated non overdrive trucks. All they accomplished was to make them a dog by spinning the engine slower. On a pickup with stock 235 tires a 3.50 gear is as tall as I would go without overdrive and maybe a 3.73 with.
Even with a V8 the aod trannys have to shift down on the slightest grade, and can smell a hill from a mile away.
ToughOldFord
Post by ToughOldFord »
For what it's worth my '77 f-150 is stock with a 300 and a C-4 auto.
