swapping from C-O-M to C6
LANCE65
Post by LANCE65 »
What all do I need to convert my truck(1965 f250 w/390) from a cruis-o-matic to a c6?
assuming the bellhousing are the same for both trannies. probably your only worries would be linkages driveshaft length speedo cable and or gear and maybe the crossmember and trans mount.
67F250CS
re: swapping from C-O-M to C6
Post by 67F250CS »
I did this very same thing to my 67. The bellhousing is thicker on the com like 3 times as thick, so shorter bolts are needed. I also had to use the front half of the donor truck driveshaft and the back half of my original. Also I just pulled the speedo cable out of the donor truck and switched the plastic gear onto my original speedo cable. My C-6 has the inner type mount gear. There are outer and inner types. Mine had a small metal clip on the tip and I just had to pull it and slip the new gear on and push the clip back on.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
