C4 Transmission Fluid type
Convert
Post by Convert »
I am rebuilding my C4 and was wondering what fluid type should go in. Used to be Type F but now they have Mercon/Dexron III. It's a '79 vintage so was going to go with the Mercon but thought I would check with the experts. :thup:
Thanks....Keith B.
KeithB
The Fleet;
1968-71 F100 Step side, 351W, C4
1970 - F100 Donor, Long Box Ranger, no motor.
2004 Yamaha FZ1
jhannahokla
re: C4 Transmission Fluid type
Post by jhannahokla »
i believe type f needs to go in there but im not 100% shure on that
James
1970 F-100/302/3spd/9 Inc RearEnd 3.50 G/R
Image Watch This BurnOut !
kknip
Post by kknip »
Check out your dipstick for the trans,sometime it is stamped on the end.I think it should be type F. :wink:
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
Clarko
Post by Clarko »
Type F from the start of Fordomatics through 1982. Mercon from 1983-up.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
hillbilly67
Post by hillbilly67 »
Everybody is right. Type F. Careful of the new oils that state "For use in all transmissions" Fine for the new ones, but our old trucks need old oil! The reasoning behind this, is the additives that are in the oils, are not compatible with the clutch materials and glue that hold them on to the plates. There is a certain amount of acids and a LOT of detergents that are in the oils. Too much of one or not enough of the other raises hell with clutch material.
The exception to this is most rebuild kits these days use new kinds of materials that enable use of all-in-one oils. Better safe than sorry, though, as not all rebuild kit manufacturers do this.
Made my first million.....too bad it was mistakes..not dollars! Now pass me that crescent hammer.
Clarko
Post by Clarko »
Type F is nice and thicker too.
Brian
Convert
Post by Convert »
Thanks for the info. I will go with good old Type F.
KeithB
The Fleet;
2004 Yamaha FZ1
