Torque specs
F250MudPatrol
Torque specs
Post by F250MudPatrol »
What are the torque specs for the bolts connecting the ring gear in a Dana 60? What are the torque specs for the bolts connecting the axle shafts to the axle housing?
The truth shall set you free.
jhannahokla
Re: Torque specs
Post by jhannahokla »
F250MudPatrol wrote:What are the torque specs for the bolts connecting the ring gear in a Dana 60? What are the torque specs for the bolts connecting the axle shafts to the axle housing?
the bolts connecting the ring gear is 40-55. couldn't find the torque specs for the axel shafts :cry:
James
1970 F-100/302/3spd/9 Inc RearEnd 3.50 G/R
Image Watch This BurnOut !
re: Torque specs
jhannahokla: the specs you gave are for a Dana 44 ring gear. For a Dana 60 ring gear, the bolts need torqued to 100-120 ft/lbs. However, my manual doesn't show specs for the axle either. :hmm:
jhannahokla
re: Torque specs
glad you caught that Keith i read every page over the axels in my book couldn't find any thing over the axel shafts but a assembly diagram is your book a chiltons too
James
