any know how to take off the inner fender were the battery..
any know how to take off the inner fender were the battery is held , where and how do i take it off , wheres the bolts at and does anyone noe where i can get a used one at mines all rusted where the battery is held.
1972 ford camper special in progress
- zakt
re: any know how to take off the inner fender were the batte
I had to pull the core support to slide mine off the firewall brackets but Im thinking you can take off the firewall bolts on the bracket but the front piece is sandwiched in the front with the coresupport and fender so might have to pull the core support no matter, anyone? I would pull the fender first since everything will still stay together at that point. Then the core support if needed to get it off? I had to brace up the inner fender at that point since this was my first time I should of taken off the fender first though
Then unbolt all the stuff on the inner fender and remove the shields and brackets in the wheel well connecting the inner fender to the firewall.
1972 Ford F350 crewcab
