Need help identifying a transmission
- clbrockman
I have bought an engine and transmission to put in my 67 and need to identify what transmission it is. The engine is a 351w out of a 1990 van and the transmission was original behind it. I have a bunch of numbers off of the tag, but don't know what they mean or how to find that out. Please let me know what I need to do to identify this.
Thanks,
Chad
Thanks,
Chad
1967 F100 "Ted's truck"
Chad
Chad
- clbrockman
re: Need help identifying a transmission
Yes it does, if that is the case, is there any way to use it without a computer? Or is the computer needed?
Chad
Chad
- ToughOldFord
If it's a E4OD then you need the computer and sensors that go to it. For instance the VSS in the rear axle, the TPS, etc. I don't know how, if possible, to bypass or override those. The E4OD is a cr*p transmission anyway.
If it's a AOD I don't believe there's a computer at all.
- kknip
The AOD only needs a throttle valve cable you can run off your carb linkage,something like a kick down rod only in reverse.I had an AOD from a 91 Mustang GT behind a 302 in a 66 long bed.I fabricated a bracket that bolted on the back left carb mounting bolt.The trans worked really well after I got the cable adjusted correctly.
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
- clbrockman
Thanks for all the answers. How do I tell the difference between and E4OD and an AOD?
THANKS!!!!
THANKS!!!!
Chad
Chad
- adrianspeeder
AOD = 14 pan bolts
E4OD = 20 pan bolts
E4OD = 20 pan bolts
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
- clbrockman
Thanks all, it is an e4od. Thanks again!
Chad
Chad
