I was wondering if any one has used a gear vendor on there truck?
If so what are the pros and cons to going this route?
Thank You
Gear Vendor
- theskytoucher
Gear Vendor
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- customcrewcab
re: Gear Vendor
we put a gear vender of a 65 mustang with an aod. not really thing bad just the price. they handle tons of power and split you gears so your third is 1 to 1 it makes it point 5. if you have an automatic thats the way to go and with the price of gas it may pay for itself in acouple of years.
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
