Here's my setup. Mallory 29440 promaster coil and Comp 9000 unilite distributor on a 351w. Standard 8mm plug wires and autolite platinum plugs.
My pickup wasn't firing, turning over fine, but no fire. It had gas, air, but no fire. I put a test light to the ignition wire going to the coil when cranking, and a big bright light, 12 volts. I put the test light on the opposite side of that same resistor and tried cranking it, and to my surprise, it started pulsing real bad! I was thinking I'd remembered that thing staying dim. Not pulsing dim, but just plain' ol staying dim...So i replaced the resistor thinking it was somehow faulty, and the pickup cranked RIGHT UP!!!! this made me smile cause i miss this baby running...
Well, the very next morning....no fire again. I tried for 10 minutes, turning over and over, but no fire. I check that resistor again, and boom, its pulsing! I get aggrevated and go to work in something OTHER than my pickup...
I check the resistor as the wife cranks it, and yeah, its pulses a bit, but then starts up and stays on.
I thought maybe the coil was getting too much voltage. I checked and its about 8-9 volts. I asked mallory and they said that the voltage isn't a set number because of the alternator.
I also thought maybe it was a cold cranking amp thing, but this battery seems good. It was a high-end battery i bought 3 months ago and never drags or anything...
I was told there could be a bypass switch going from the starter selenoid to the coil that's missing... I know it would be missing because the only wire going to that coil is either from the distributor or the main ignition wire.
I guess i need to get to the question. Has anyone had a similar experience with this? Could i still be getting too much voltage to the coil? The PO had TWO inline resistors cutting juice before the coil, and i never had any problem with it until a radiator leak spilt antifreeze all over those two resistors and i assume fried them, cause they quit working.
Or could it be my resistor? Not enough wattage? Not hot enough to crank or something? As you can tell, i don't have just the firmest grasp of what i'm working with, but i'm eager to learn and continue driving this wonderful pickup...
any help is greatly appreciated! Thank you for assisting in the "Help Stephen successfully move to Houston" foundation!
