Overdrive tranny
theskytoucher
Overdrive tranny
Post by theskytoucher »
I was wondering if there is an overdrive manuel transmission that is a bolt in replacement for a t-18.
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
willowbilly3
re: Overdrive tranny
Post by willowbilly3 »
The T85 should be pretty close. I am not sure if you can keep the same bell housing or not and the driveshaft length might be a bit different.
theskytoucher
Is the t85 a 4 speed or a 5 speed
-Troy-
1976 Ford F-150 4x4
willowbilly3
It's actually a 3 speed but has overdrive in every gear. As originally installed a lockout device keeps it from working in first so it would be a 5 speed. With manual contol it would be 6.
theskytoucher
I've never heard of anything like that. Is it a Column shift or floor. And if its a colum can it be converted to a floor.
-Troy-
1976 Ford F-150 4x4
steveheer
Post by steveheer »
They are column shift but just like any other 3 speed they could be converted to the floor. The overdrive works off a sprag clutch off the back of the 3 speed so there is a lockout lever. When the lockout is pulled it works like any other 3 speed. When it is released it will coast forward until the transmission output reaches driveline speed. In other words from a dead stop it starts normally then if you let off the gas, the engine will idle while the truck is still at speed. Anyway that's the overrunning clutch that the overdrive requires to "overdrive". So if you take it to say 50 mph, activate the selenoid, then let off the gas (or clutch it) you are in OD.
I have one in my 69 and it's cool. The only drawbacks are no syncronized first gear (which the original toploader had) and hard to find parts.
Oh, one other thing. They are not a good trans for pulling boats out of the water! They have around a 3 to 1 first gear--ok for normal stuff or light towing--
IMO
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
theskytoucher
Well im not planning on doing any pulling im building a street truck so that might be the way to go. Thanks
-Troy-
1976 Ford F-150 4x4
