Does anybody know if ford ever put a 1 piece drive lines on any of the 68 or close trucks? I need a one piece drice line with u-joints on both ends with a slip joint in the middle.
Can anybody help me?
1 piece drive lines
re: 1 piece drive lines
All SWB trucks came with a one-piece driveshaft, with a slip-yoke like a car's....all LWB had two-piece driveshafts. What are you planning?
how is it possible to have a one piece drive shaft with a slip joint in the middle? Im not under standing.
if you want a one piece drive shaft you need to know what trans and if its a long box or short box but remember the slip yok is going to be on the trans.
so if you got a C6 with the slip yok on the trans and you want a one peace drive shaft often you can use the drive shaft out of a ford van from 74 ta 86 depending on wheel base
WHAT ?
I think he meant that he wanted to do away with the two halves connected at the carrier bearing, and go straight from the tranny to the rearend.
I also forgot to mention that the SWB 4x4s did get a one-piece driveshaft with a middle slip-yoke, since you can't have a conventional car-type slip yoke out of the back of the transfer case....at least that's what my '69 SWB 4x4 has, as shown here:
