Hey guys, new here and have a question about np435 tranny. I'm putting it is my 70 Bronco.
Here's the story. Got tranny from junk yard and it wasn't in the truck at the time. There was no front bearing retainer and the front bearing was rusted badly. Anyway, I pulled the input shaft and replaced the bearing. The new bearing and old bearing had matching parts numbers. No problems yet. Acquired a bearing retainer from Broncograveyard and pressed race in place. Here's the problem. The race will not fit all the way down on the bearing. It aint even close. Everything I can find (which aint much) that includes the part # for this race says it's the right one. I don't see how that is possible, but that's what it says.
Does anyone here have the part numbers for that race/bearing?
Anyone with any ideas?
Thanks
NP435 PART NUMBERS
NP435 PART NUMBERS
IF YOU'RE NOT CHEATING YOU'RE NOT TRYING
- heep70
Get with 4x4x4crewcab. He has some resources that might help ya out.
to the site.
to the site.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 4x4x4crewcab
re: NP435 PART NUMBERS
Lets start here: (see picture)
I really should have the trans tag or I.D. # to know for sure. My best guess is the following
I find 3 different choices for the front bearing retainer for this era NP435
(7050 number in picture)
C4TZ.7050.A 4.82" overall length 5.124" flange O.D. 2.8428" flange I.D.
C5TZ.7050.A 4.57" overall length 4.849 diameter with 4 11/32" holes
C5TZ.7050.B 5.39" overall length 5.125 diameter with 4 11/32 holes
all of these use the same C4TZ.7048.A input seal and the same CODW.4628.A race and the same CODW.4630.A bearing
The NP435 trans catalog also shows (depending on trans I.D. #) 3 different input shafts
9 3/8 long
8.991" long
10.061" long
The above numbers are Ford part numbers from the catalog, Any numbers you may find on the parts will be engineering number for crossover. The bearing and race should have industrial numbers on the sides of them.
9 3/8 long
8.991" long
10.061" long
Mark
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
1999 Ford Windstar
- 460 crew
:stupid: When the guys at my Carquest pass on. The man with all the right #'s
Re: re: NP435 PART NUMBERS
WOW . Guess I came to the right spot! Thanks!4x4x4crewcab wrote:Lets start here: (see picture)
9 3/8 long
8.991" long
10.061" long
