Just pick up a 72 f 100 with a 360.
I go to put the key in and it did nothing start the truck. I replace the starting relay. That did nothing to fix the problem. You can crank the truck over jumping the relay but nothing with the key.
I replace the ignition swith and the key tumbler with new. this still did not fix the problem
Could it be the coil or a wire on the coil causing this problem.
How would one go about troubleshooting then fixing this issue.
Ignition Problem
re: Ignition Problem
It is Auto Trans, Where might that switch be located?
Well with your information I was able to get the truck started with the key. Thanks so much now I think I will have to fix that part
- flyboy2610
Glad you got it going!
